MOAT connection guide
Follow these steps to connect your MOAT data to Supermetrics and use your data in Google Sheets, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the MOAT connector, you need an API token generated for you on the platform. To obtain your API token, reach out to your MOAT or Oracle representative and ask them to create and share the token with you.
Note that each API token has access to a specific set of MOAT datasets, so make sure that your API token has permissions to all the relevant datasets you want to use in Supermetrics.
  • Statistics: Pull all the dimensions and metrics from MOAT, based on the dataset selected.
  3. Click Create new query.
  4. Under Data source, select MOAT.
  5. Enter the API token.
  6. Enter a name for your account for you to identify it later.
  8. Click Start.
Excel
  1. Open an Excel file.
  3. Under Data source, select MOAT.
  4. Enter the API token.
  5. Enter a name for your account for you to identify it later.
  7. Click Start.
Power BI
  3. Click Select data source.
  4. Select the MOAT data source.
  7. Fill in the query details.
  8. Click Run query to test your query.
The Supermetrics API
  4. Click Select data source.
  5. Select the MOAT data source.
  6. Enter the API token.
  7. Enter a name for your account for you to identify it later.
  8. Click Start.
Supermetrics Hub
  4. Hover over the MOAT data source, and click Connect.
  7. Click Start.
