With the Salesforce data source connector, you can explore how your opportunities, lead numbers or closed sales have developed over time.
For a full list of metrics and dimensions available in our Salesforce data source connector, take a look at our Salesforce documentation.
Once you've connected to Salesforce, you're ready to create your first queries!
Try these queries
You can choose to fetch opportunities and leads by created date, last modified date, or closed/conversion date. The default setting is the created date. Learn how to use the advanced date settings in Salesforce.
See leads by date
Take a look at the number of leads created each day. In this example, we view this data for the previous month.
The "Leads" metric shows the total number of leads.
- Set the date range to Last month.
- Select the Leads metric.
See annual lead count by month
Fetch the annual lead count for the year and compare it with the previous year.
- Set the date range to This year.
- Select the Year and month dimension to split the query results by month.
- Set the Comparison date range to Previous period.
See leads by status
Explore the statuses of the leads created in the last 28 days.
For best results in Looker Studio, use the table or bar chart type.
- Select the Lead status dimension to split the query results by date.
See number of opportunities per owner
Take a look at the distribution of opportunities in your team. In this example, we take a look at the data from last week and compare that to the week before that.
The "Opportunity count" metric shows the total amount of opportunities.
- Select the Opportunity count metric.
- Select the Opportunity owner dimension to split the query results by opportunity owner.
