Similarweb connection guide
Follow these steps to connect your Similarweb data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
You need to create an API key to connect Supermetrics to your Similarweb account. Note that only account admins can generate new API keys in Similarweb.
To create the API key:
  1. Log in to the Similarweb platform.
  2. From the left menu, select Settings > Account.
  3. Under API, select Standard API.
  4. Click Generate a new API key
  5. Select the primary user of the API key you're creating.
  6. Click Create. Your key will be displayed in the Generated Keys table.
  • Traffic and engagement: Get the traffic volume and engagement for one or multiple websites.
  • Desktop traffic sources: Understand what channels visitors are coming from for one or multiple websites. Only returns data for desktop users.
  • Desktop keywords: Analyze what search engine keywords are attracting visitors and where they enter one or multiple websites. Only returns data for desktop users.
  • Desktop PPC spend: Get estimated paid search spending for one or multiple websites. Only returns data for desktop users.
  • Search keyword competitors: Analyze what the biggest competing websites are on search engines, for one or multiple websites.
  • Top sites: Get ranking data for the top websites in a selected industry.
  • App performance: Get the overall rating and rank of any mobile app in the Google Play Store or the Apple App Store.
  3. Click Create new query.
  4. Under Data source, select Similarweb.
  5. Enter your API Key.
  6. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
  9. Navigate to Report configuration and select a query type.
  2. Navigate to Similarweb and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Similarweb requires authorization to connect to data").
  6. Enter your API Key.
  7. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Choose to make this connection shared or private.
  9. Click Start.
  10. Select a query type and click Next.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Similarweb.
  4. Enter your API Key.
  5. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  7. Click Start.
  8. Navigate to Report configuration and select a query type.
Data warehouse
  3. Click + Create transfer.
  4. Select the Similarweb data source.
  7. Accept the agreement.
  8. Click Authorize with Similarweb.
  9. Enter your API Key.
  10. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  11. Click Start.
  12. Select the accounts and other settings you'd like to include in your reporting and define the transfer settings.
  13. Click Submit.
  14. Click Save.
  3. Click Create new.
  4. Select the Similarweb data source, and click OK.
  7. Enter your API Key.
  8. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  9. Click Start.
  10. In the transfer setup view, select the accounts and other settings you'd like to include in your reporting.
  11. Click Create transfer.
Power BI
  3. Click Select data source.
  7. Click Start.
  8. Fill in the query details.
The Supermetrics API
  4. Click Select data source.
  5. Select the Similarweb data source.
  8. Click Start.
Supermetrics Hub
  4. Hover over the Similarweb data source, and click Connect.
  7. Click Start.
