Follow these steps to connect your Capterra Reviews data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Capterra Reviews, you need a Capterra product identifier for search. This identifier can be taken from the URL of the product page in Capterra.
For example, if the product URL in Capterra is capterra[dot]com/p/135003/Slack, the identifier is 135003.
- Reviews: Get data on reviewers, review title, rating, text, pros, cons, and dates with the number of reviews and average ratings.
- Under Data source, select Capterra Reviews.
- Navigate to Report configuration. Enter your software ID in the field of the same name.
- Navigate to Capterra Reviews and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Capterra Reviews requires authorization to connect to data").
- Select the Supermetrics team to use in your report and a query type.
- Click Next.
- Enter your software ID in the field of the same name.
- Click + Create transfer.
- Select the Capterra Reviews data source.
- Accept the agreement.
- Click Authorize with Capterra Reviews.
- Select the software IDs you'd like to include in your reporting and define the transfer settings.
- Click Submit.
- Click Save.
- Select the Capterra Reviews data source, and click OK.
- In the transfer setup view, select the software IDs you'd like to include in your reporting.
- Click Create transfer.
Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Capterra Reviews data source, and click Connect.
