Use this guide to connect your Readpeak data to Supermetrics.
You'll need a Readpeak account with the Administrator, Producer, or Manager user role to connect.
You'll also need a copy of the account's API key.
- Log in to Readpeak.
- In the top right corner, click Settings.
- Open the Profile tab.
- Check your account's user role under Role. If you don't have the right permissions, get in touch with your administrator for help.
- Log in to Readpeak's API manager.
- Navigate to the top left corner. You'll find your key under Your API Key.
Be sure to keep your API key safe and secure, as it gives access to all of your account's data.
For Excel users
- Click Create query.
- Under Data source, select Readpeak.
- Enter your account name (this doesn't have to match your Readpeak account's name).
- Enter your API key.
- Navigate to Readpeak and click Try.
- Click Authorize.
- Click Authorize.
- UnderData source, select Readpeak.
