Follow these steps to connect your Xandr data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before connecting Xandr to Supermetrics, you need a Xandr username and password to use the Xandr API. Take a look at Xandr's help for instructions on how to get the credentials. Note that the Microsoft account you log in to Xandr with isn't enough for API access.
- Advertiser report: View performance, revenue, and profit data across a specific advertiser's creatives and campaigns. This report is available to network and advertiser users.
- Under Data source, select Xandr.
- Enter your Xandr username and password.
- Navigate to Xandr and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Xandr requires authorization to connect to data").
- Select the accounts to use in your report and a query type.
- Click Next.
- Click + Create transfer.
- Select the Xandr data source.
- Accept the agreement.
- Click Authorize with Xandr.
- Click Submit.
- Click Save.
- Select the Xandr data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Xandr data source, and click Connect.
