This guide contains all permissions and requirements for connecting your Amazon Seller Central data to Supermetrics.
You must be the primary user of the Amazon Seller Central account or enable Grant universal site admin access permissions for a secondary user account.
To assign admin permissions to a secondary account:
- Go to Settings → User Permissions in Amazon Seller Central.
- Click Manage permissions.
Before starting the connection process, please check the main marketplace and region for your Amazon Seller account.
- Sales and traffic by date
- Sales and traffic by ASIN
- Orders
When connecting to Amazon Seller Central, you need to log in to Amazon and select the marketplaces to include in your report.
- Select the Amazon Seller Central data source on the Supermetrics Hub or in the data destination.
- Log in to your Amazon account.
- Select the marketplace account where you have your main store.
- Click Confirm to authorize the Supermetrics app to access your data.
- In your data destination, select the marketplaces you'd like to include in your reporting and a query type to use.
You can also connect to Amazon Seller Central from these destinations:
If you're unable to fetch or select your accounts after connecting Amazon Seller Central to Supermetrics, this is likely due to selecting the wrong marketplace account when setting up the connection. Please try creating a new connection and make sure you select the correct main marketplace and region.
