Learn how to connect Piwik PRO to Supermetrics, and start adding user analytics data and more to your reports.
To connect to Piwik PRO, you'll need copies of your account name, client ID, and client secret.
- Log in to your Piwik PRO dashboard.
- Your account name is the first part of the URL you see in your browser's address bar.
- For example, if your URL is exampleABC.piwik.pro, then your account name is exampleABC.
- Click Menu in the top left.
- Select Profile from the dropdown.
- Select the API Keys tab on the left.
- Click Create key.
- Give your key a memorable name.
- Copy the client ID and client secret. Keep them in a secure, safe place.
- Analytics: Fetch website and product analytics data from Piwik PRO's Analytics product.
- Under Data source, select Piwik PRO.
- Enter your account name, client ID, and client secret.
- Navigate to Piwik PRO and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Piwik PRO requires authorization to connect to data").
- Click Authorize.
- Select a query type.
