X Organic (Twitter) connection guide
Follow these steps to connect your X Organic (Twitter) data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the X Organic (Twitter) data source connector to fetch organic tweet data, you must have a completed Twitter profile and an active Twitter Ads account connected to it. Follow these steps to create a Twitter Ads account.
If the account is already linked to a Twitter Ads account, and you didn't create a new account, set up Tweet permissions in Twitter Ads account:
  1. Open the Twitter Ads portal.
  2. In the top right-hand corner, click your account name and select Edit access to account.
  3. Click Edit access.
  4. Check the box for Can compose promotable Tweets next to your account.
  5. Click Save changes.
Access Tweets from other Twitter profiles
To fetch tweets for another Twitter account with multi-user login, you must be added as a Campaign analyst or Administrator to the other Twitter Ads account.
Please ask the administrator of the other Twitter account to do the following:
  1. Create a Twitter ad account if they don’t have one already. Follow these steps to create a Twitter Ads account.
  2. Navigate to Twitter Ads.
  3. Click the account name in the top right corner and select Edit access to account.
  4. Click Add access.
  5. Enter the name of your Twitter handle in the text box, select Campaign analyst, and save the changes.
  • Profile info: Get Twitter profile-level metrics.
  • Tweet engagement: Measure the organic performance of your tweets.
  3. Click Create new query.
  4. Under Data source, select X Organic (Twitter).
  6. Click Start.
  7. Log in to the Twitter account you want to fetch data from.
  8. Click Authorize app to allow the Supermetrics app to access your profile data.
  9. Select the accounts you'd like to include in your reporting.
  10. Navigate to Report configuration and select a query type.
  1. To start using X Organic (Twitter) in Looker Studio, click this link.
  2. You'll see two buttons that read Authorize. If you're using Supermetrics for the first time, click the left-hand one and log in with the Google Account you use with Supermetrics.
  3. Once that's done, or if you've done it before, click the right-hand Authorize button (under "X Organic (Twitter) requires authorization to connect to data").
  4. Select a team that has access to the account you want to connect.
  6. Click Start.
  10. Select a query type, and click Next.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select X Organic (Twitter).
  5. Click Start.
  6. Log in to the Twitter account you want to fetch data from.
  7. Click Authorize app to allow the Supermetrics app to access your profile data.
  8. Select the accounts you'd like to include in your reporting.
  9. Navigate to Report configuration and select a query type.
Data warehouse
  3. Click +Create transfer.
  4. Select the X Organic (Twitter) data source.
  7. Accept the agreement.
  8. Click Authorize with X Organic (Twitter).
  9. Log in to the Twitter account you want to fetch data from.
  10. Select the accounts you'd like to include in your reporting and define the transfer settings.
  11. Click Submit.
  12. Click Save.
  2. In the left-side menu, under Export, go to Data warehousing → Transfers.
  3. Click Create new.
  7. Click Start.
  8. Log in to the Twitter account you want to fetch data from.
  9. Click Authorize app to allow the Supermetrics app to access your profile data.
  11. Click Create transfer.
Power BI
  3. Click Select data source.
  5. Click Start.
  9. Fill in the query details.
  10. Click Run query to test your query.
The Supermetrics API
  4. Click Select data source.
  5. Select the X Organic (Twitter) data source.
  6. Click Start.
  10. Fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  11. Click Run to test your query.
Supermetrics Hub
  4. Hover over the X Organic (Twitter) data source, and click Connect.
  5. Click Start.
