Nexxen DSP connection guide
Follow these steps to connect your Nexxen DSP data to Supermetrics and use your data in Google Sheets, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the Nexxen DSP data source connector, you need your Nexxen DSP client ID, client secret, and appropriate permissions for data access on your account.
To pull reporting data, you need to have access to Reporting API.
  • Performance: Build reports with your performance data
  3. Click Create new query.
  4. Under Data source, select Nexxen DSP.
  5. Enter your client ID and client secret.
  6. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
Excel
  1. Open an Excel file.
  3. Under Data source, select Nexxen DSP.
  4. Enter your client ID and client secret.
  5. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  7. Click Start.
Power BI
  3. Click Select data source.
  4. Select the Nexxen DSP data source.
  7. Click Start.
  8. Fill in the query details.
The Supermetrics API
  4. Click Select data source.
  5. Select the Nexxen DSP data source.
  6. Enter your client ID and client secret.
  7. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
Supermetrics Hub
  4. Hover over the Nexxen DSP data source, and click Connect.
  7. Click Start.
