Use the Google Search Console data source to centralize data in one location and create historical reports to see how your visibility has improved over time. You can pull data such as queries, landing page analytics, geo, and sitemaps.
Once you've connected to Google Search Console, you're ready to create your first query in Google Sheets, Looker Studio (formerly Data Studio), or Excel.
When connecting to the Google Search Console data source in Looker Studio, you must select a query type to use. The query type defines what sort of metrics and dimensions are available.
- Search analytics
- Sitemaps
- Crawl error samples
- Crawl error stats
- Search appearance analytics
Query types are not used in other data destinations, but you can only use metrics from the same group in a query.
Try these queries
See clicks and impressions
Take a look at how your clicks and impressions have evolved over the month.
In Looker Studio, use the "Search analytics" query type.
For best results in Looker Studio, use the line or combo chart type.
- Set the date range to Month to date.
- Select the Clicks and Impressions metrics.
- Set a filter with the Search type field and the EQUALS operator, and set the value to WEB. This matches your query results with the Google Search Console user interface.
See clicks, click-through-rate, impressions, and average position over time
Get a wider view of the interactions of your audience. See how you're positioned in search results, and how many people have seen you in their search results. In this example, we take a look at the data for the year so far.
The “CTR” metric shows the Click Through Rate (clicks divided by impressions). The "Average position" metric shows the average organic position in Google search results.
- Set the date range to Year to date.
- Select the Clicks, CTR, Impressions, and Average position metrics.
- Select the Week dimension to split the query results by week.
See clicks, impressions, and average position per query
Take a look at the most popular search queries your audience uses.
In Looker Studio, use the "Search appearance analytics" query type. Select the search appearance dimension to use this query type.
- Set the date range to Last 7 days.
- Select the Clicks, Impressions, and Average position metrics.
- Select the Search query and Search appearance dimensions.
