Squarespace Commerce connection guide
This guide contains all permissions and requirements for connecting your Squarespace Commerce data to Supermetrics.
You need an API key in order to connect to Squarespace Commerce.
Follow the steps below to generate an API key:
  1. Log in to your Squarespace site.
  2. In the left side navigation, click Settings.
  3. Select Developer Tools.
  4. Click Developer API Keys.
  5. Click the GENERATE KEY button.
  6. In the dialog, add a key name under "KEY NAME", and enable “Read only” permission on the following: Products, Orders, Profiles
  7. Click on GENERATE KEY in the top right of the dialog.
  8. Record the generated key in a safe and secure place.
For security reasons, this is the only time the API key is visible. API keys will never expire as long as the merchant site remains active.
More information on how to authenticate Squarespace Commerce can be found here.
  • Orders: Fetch detailed insights about your shop orders.
When connecting to Squarespace Commerce, you need to provide your API credentials when prompted.
  1. Select the Squarespace Commerce data source on the Supermetrics Hub or in the data destination.
  2. Insert API key.
  4. Click Start.
  5. In your data destination, select if you want to fetch data based on created or modified date.
You can also connect to Squarespace Commerce from these destinations:
