This guide contains all permissions and requirements for connecting your Amazon DSP data to Supermetrics.
Availability
Amazon Ads is available only in Excel and our data warehouse and API data destinations.
After you connect to the data source on the Hub, you can use the data source connection in the available destinations.
To connect, you need an Amazon user account with access to an Amazon DSP account. See Amazon's guide on obtaining consent to access an Amazon DSP account.
The account should have View and Edit permissions for Campaign Management.
- Campaign: Get detailed performance metrics by order, line-item, and creative.
- Inventory: Get detailed performance metrics by supply and site
When connecting to Amazon DSP, you need to log in to Amazon and select the query type and account when prompted.
- Select the Amazon DSP data source on the Supermetrics Hub or in the data destination.
- Select your account's region.
- Give your account a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
- Log in to your Amazon account.
- Click Allow to allow the Supermetrics app to access your profile data.
- In your data destination, select the query type to use and an account to pull data from.
You can also connect to Amazon DSP from these destinations:
