Follow these steps to connect your Partnerize data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the Partnerize connector, you need a copy of your Application Key and API Key.
- Log in to your account on the Partnerize console.
- In the Partnerize console, click your account name in the top left.
- From the drop-down list, select Account settings.
- On the left hand side, click the eye icons next to Application Key and API Key to reveal them.
- Copy the Application Key and API Key to a safe place.
Supermetrics supports 3 Partnerize report types to fetch performance data of your partnerships:
- Impression report
- Click report
- Conversion report
- Under Data source, select Partnerize.
- Enter your Application Key and API Key.
- Select a query type.
- Navigate to Partnerize and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Partnerize requires authorization to connect to data").
- Select the accounts and a query type you'd like to include in your reporting, and click Next.
- Under Data Source, select Partnerize.
- Click + Create transfer.
- Select the Partnerize data source.
- Accept the agreement.
- Click Authorize with Partnerize.
- Click Submit.
- Click Save.
- Select the Partnerize data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Partnerize data source, and click Connect.
