Use this guide to connect your Awin data to Supermetrics.
To connect Supermetrics to Awin, you need API credentials. Learn how to create these credentials.
Supermetrics supports 3 Awin query types.
- Publisher report: Get aggregate performance metrics, like impressions and transactions, per publisher.
- Creative report: Fetch aggregate performance metrics, like impressions and transactions, per creative used.
- Transactions report: Pull all individual transactions to check their status and commissions paid.
For Excel users
- Under Data source, select Awin.
- Enter your account name and API key, and click Start.
- Select your accounts.
- Navigate to "Report configuration", and select a query type and filters.
- Navigate to Awin and click Try.
- Click Authorize.
- If you're connecting Awin for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
