Microsoft Advertising connection guide
Follow these steps to connect your Microsoft Advertising data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Microsoft Advertising, you need:
  3. Click Create new query.
  4. Under Data source, select Microsoft Advertising.
  6. Click Start.
  7. Enter your Microsoft email address and click Next.
  8. Enter your Microsoft password and click Sign in.
  9. Click Accept.
  10. Select the accounts you'd like to include in your reporting.
  2. Navigate to Microsoft Advertising and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Microsoft Advertising requires authorization to connect to data").
  7. Click Start.
  8. Enter your Microsoft email address and click Next.
  9. Enter your Microsoft password and click Sign in.
  10. Click Accept.
  11. Select the accounts you'd like to include in your reporting.
  12. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  13. In the pane's top right, click Connect.
  14. Click Create report.
  15. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Microsoft Advertising.
  5. Click Start.
  6. Enter your Microsoft email address and click Next.
  7. Enter your Microsoft password and click Sign in.
  8. Click Accept.
  9. Select the accounts you'd like to include in your reporting.
Data warehouse
  3. Click + Create transfer.
  4. Select the Microsoft Ads data source.
  7. Accept the agreement.
  8. Click Authorize with Microsoft Ads.
  9. Click Start.
  10. Enter your Microsoft email address and click Next.
  11. Enter your Microsoft password and click Sign in.
  12. Click Accept.
  13. Select the accounts you'd like to include in your reporting and define the transfer settings.
  14. Click Submit.
  15. Click Save.
  3. Click Create new.
  4. Select the Microsoft Ads data source, and click OK.
  7. Click Start.
  10. Click Accept.
  11. In the transfer setup view, select the accounts you'd like to include in your reporting.
  12. Click Create transfer.
Power BI
  3. Click Select data source.
  5. Click Start.
  8. Click Accept.
  9. Fill in the query details.
  10. Click Run query to test your query.
The Supermetrics API
  4. Click Select data source.
  5. Select the Microsoft Ads data source.
  6. Click Start.
  9. Click Accept.
  10. Fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  11. Click Run to test your query.
Supermetrics Hub
  4. Hover over the Microsoft Ads data source, and click Connect.
  5. Click Start.
  8. Click Accept.
