Criteo Retail Media connection guide
Follow these steps to connect your Criteo Retail Media data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, and Excel. You can also connect to data sources from the Supermetrics Hub.
Before using the Criteo Retail Media connector, you need:
  • An API user with a client ID and client secret
  • An app with at least Read access for all elements of the Retail Media API.
To create these credentials, follow our Criteo permissions guide.
  • Campaign: An overview of the performance of a specific advertising campaign over a given period of time using the Clicks, Impressions, CTR, CPM, Attributed orders, Units, Sales, Cost, CPC, Unique visitors, and Frequency metrics
  • Page type: Campaign data split by Page type
  • Product: Campaign data split by Product
  • Keyword: Campaign data split by Keyword
  • Attributed transactions: Insights into the performance of ad campaigns by attributing conversions to specific advertising initiatives
  3. Click Create new query.
  4. Under Data source, select Criteo Retail Media.
  5. Enter the Client ID and Client secret.
  6. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
  9. Select a query type you'd like to use in your reporting.
  2. Navigate to Criteo Retail Media and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Criteo Retail Media requires authorization to connect to data").
  6. Enter the Client ID and Client secret.
  7. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Choose to make this connection shared or private.
  9. Click Start.
  10. Select a query type you'd like to use in your reporting, and click Next.
  11. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. In the pane's top right, click Connect.
  13. Click Create report.
  14. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Criteo Retail Media.
  4. Enter the Client ID and Client secret.
  5. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  7. Click Start.
  8. Select a query type you'd like to use in your reporting.
Supermetrics Hub
  4. Hover over the Criteo Retail Media data source, and click Connect.
  7. Click Start.
