Follow the steps below to connect your Spotify Ads data to Supermetrics.
- Under Data source, select Spotify Ads.
- Log in with the account you use to log in to Spotify, or log in with a Facebook, Apple, or Google Account (this doesn't need to be the same Google Account you use to log in to Supermetrics).
- Click Log in.
- Click Agree.
- Navigate to Spotify Ads and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Spotify Ads requires authorization to connect to data").
- Click Log in.
- Click Agree.
- Click Log in.
- Click Agree.
