This guide contains all permissions and requirements for connecting your Shopee Commerce data to Supermetrics.
To pull commerce data from Shopee using Supermetrics, you need a Shopee account.
In addition, you need:
- You must authenticate using a normal Shop account. Sub-accounts are not compatible with the connector.
- You need the email/phone number/user name and password of the Shop account.
Learn more about different types of Shopee accounts.
- Orders: Retrieve detailed insights about your shop orders.
- Order Items: Retrieve detailed insights about products ordered from your shop.
When connecting to Shopee Commerce, you need to Shopee Commerce and select the shop region when prompted.
- Select the Shopee Commerce data source on the Supermetrics Hub or in the data destination.
- Select your store region from the dropdown and insert your email/phone number/user name and password.
- Confirm the authorization for Supermetrics to access your Shopee data.
- In your data destination, account to pull data from and a query type, if prompted.
You can also connect to Shopee Commerce from these destinations:
