Pinterest Ads report building guide
Pull your basic ad metrics from Pinterest and use your data to better optimize future content needs. Combine Pinterest Ads data to other visual social media channels such as Instagram to see the similarities and differences in campaign success.
Once you’ve connected to Pinterest Ads, you’re ready to create your first query in Google Sheets, Looker Studio (formerly Data Studio), or Excel.
Try these queries
You can adjust the conversion date and attribution window for conversions in the data source connection options. Learn more about the attribution window in Pinterest Ads.
See cost, conversions, and conversion value
Take a look at how your promoted Pins have affected your conversions over time, in this example for last month.
The “Cost” metric shows the money you spent for promoted Pins, in the currency of the advertiser. The “Conversions (Checkout)” metric shows the total number of checkout events that resulted from interactions with your ad, and the “Conversions Value (Checkout)” metric shows the total value of checkout events resulting from interactions with your ad.
  1. Set the date range to Last month.
  2. Select the Cost, Conversions (Checkout), and Conversions Value (Checkout) metrics.
  3. Select the Date dimension to split the query results by date.
See return on ad spend
Find out how your average return on ad spend is doing. In this example, we take a look at how the ROAS looks for the past month or so compared to the previous period.
The “ROAS (Checkout)” metric shows the average return on ad spend for checkout events.
  2. Select the ROAS (Checkout) metric.
  3. Set the Comparison date range to Previous period.
See impressions of your Pins
Take a look at how many impressions your Pins have received in the past month or so compared to the previous period.
The “Impressions” metric shows the number of impressions from earned and paid sources.
For best results in Looker Studio, use the line chart type.
  2. Select the Impressions metric.
  3. Select the Date dimension to split the results by date.
  4. Set the Comparison date range to Previous period.
See cost and conversion per campaign
Explore your campaign spend, and which campaigns have attracted most conversions this year.
The “Cost” metric shows the money you spent for promoted Pins, in the currency of the advertiser. The “Conversions (Checkout)” metric shows the total number of checkout events that resulted from interactions with your ad.
  1. Set the date range to Year to date.
  2. Select the Cost and Conversions (Checkout) metrics.
  3. Select the Campaign name dimension.
See the Supermetrics blog for social media reporting and Pinterest traffic analytics.
