Learn how to connect your HubSpot data to Supermetrics.
To connect, you'll need a HubSpot account with either of these user roles:
- Admin
- Super Admin or Owner (full access)
For Excel users
- Under Data source, select HubSpot.
- Enter your email and password, and click Log in.
- Click Allow, and then choose an account.
- Click Grant access.
If you see a message reading "Request for integration permissions", your account doesn't have the permissions it needs to connect to Supermetrics. Contact your HubSpot administrator for help.
- Navigate to HubSpot and click Try.
- Click Authorize.
- If you're connecting HubSpot for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
