Tradedoubler connection guide
Follow these steps to connect your Tradedoubler data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your Tradedoubler account, you need to create an API client and client secret.
Note that only account owners can generate new API clients in Tradedoubler. Please contact Tradedoubler if you're not sure who the account owner is.
Create a Tradedoubler API client
  1. Log in to the Tradedoubler API Client UI.
  2. Create a client which provides a client ID and client secret. Note that the client secret is only shown once. Copy the client secret and keep it safe.
  • Program: Get aggregate performance metrics, such as impressions and clicks, per affiliate program.
  • Affiliate: Get aggregate performance metrics, such as impressions and clicks, per affiliate affiliate site.
  • Ad: Get aggregate performance metrics, such as impressions and clicks, per individual ad.
  3. Click Create new query.
  4. Under Data source, select Tradedoubler.
  5. Enter your Tradedoubler username, password, client ID, and client secret.
  6. Give your account a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
  9. Navigate to Report configuration and select a query type.
  2. Navigate to Tradedoubler and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Tradedoubler requires authorization to connect to data").
  7. Enter your Tradedoubler username, password, client ID, and client secret.
  8. Give your account a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  9. Click Start.
  10. Select a query type to use in your reporting, and click Next.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Tradedoubler.
  4. Enter your Tradedoubler username, password, client ID, and client secret.
  5. Give your account a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  7. Click Start.
  8. Navigate to Report configuration and select a query type.
Data warehouse
  3. Click + Create transfer.
  4. Select the Tradedoubler data source.
  7. Accept the agreement.
  8. Click Authorize with Tradedoubler.
  9. Enter your Tradedoubler username, password, client ID, and client secret.
  10. Give your account a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  11. Click Start.
  13. Click Submit.
  14. Click Save.
  3. Click Create new.
  4. Select the Tradedoubler data source, and click OK.
  9. Click Start.
  11. Click Create transfer.
Power BI
  3. Click Select data source.
  7. Click Start.
  8. Fill in the query details.
The Supermetrics API
  4. Click Select data source.
  5. Select the Tradedoubler data source.
  6. Enter your Tradedoubler username, password, client ID, and client secret.
  7. Give your account a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
Supermetrics Hub
  4. Hover over the Tradedoubler data source, and click Connect.
  7. Click Start.
