This guide contains all permissions and requirements for connecting your Pinterest Ads data to Supermetrics.
To connect to Pinterest Ads, you need a Pinterest user account with at least Admin or Campaign access to an ad account.
When connecting to Pinterest Ads, you need to provide your Pinterest credentials and select the accounts to pull data from.
- Select the Pinterest Ads data source on the Supermetrics Hub or in the data destination.
- Enter your email address and password, and click Log in.
- Click Give access.
- In your data destination, select the accounts to use in your reporting.
You can also connect to Pinterest Ads from these destinations:
