About IP address allowlisting for data warehouse destinations
Note
This article applies to IP address allowlisting when connecting to data warehouse destinations. If you're using our database connector, see the IP address allowlisting article for database connections.
When setting up data warehouse destinations with Supermetrics, make sure that you allow the Supermetrics IP addresses to access your data destination.
Access should be granted to the following Supermetrics IP addresses:
  • 18.202.154.254/32
  • 34.255.31.19/32
  • 52.50.123.181/32
  • 54.246.196.255/32
  • 54.73.205.239/32
  • 54.75.114.151/32
  • Don’t forget to add your own IP address.
Access is needed also for the following IP ranges:
  • 34.140.128.0/24
  • 34.48.0.128/26
Note
Please also grant access to the following Supermetrics IP addresses, which have been deprecated but are still in active use. These will be fully removed on January 14, 2025.
  • 23.20.234.176/32
  • 54.155.253.26/32
  • 54.217.129.200/32
  • 54.220.179.34/32
  • 54.247.165.52/32
  • 54.75.55.54/32
  • 54.75.80.21/32
