Use these functions to create custom fields in Supermetrics.
Function name | Description |
Absolute | Gets the absolute value from a selected field. For example, abs(10) and abs(-10) would both have 10 as their result. |
Apply date format | Converts date values to the specified format. |
Concatenate | Allows you to combine text strings or fields into one single field. |
Convert data type | Converts data from one type into another, and returns a default result if the change isn't possible. Learn more about our supported data types. For example, convert a date into text by entering the value "string" in the "Type" field. |
Divide | Divides a field by a certain value. For example, use it to divide "Clicks" by any given number, or by another numeric field in your data source. |
Extract substring | Extract part of a text string based on the number of characters in the string. "Start" defines which character in the string will begin the extracted text, and "Length" defines how many characters will be included in the text. For example, setting the start to 1 and length to 5 would turn the words "Black Friday" into "Black". |
Lower case | Converts any text to lowercase. For example, using it on "Black Friday" would change the text to "black friday". |
Multiply | Allows you to multiply the value for a field by a given number or the value from another field. |
Replace empty values | Sets a fallback value for any fields that return no data. For example, use it to fill in fields for nameless campaigns with something like "Unknown campaign". |
Return bigger value of out two | Selects the greater value from two options. For example, if you specify a value of 100 and select a field to compare that value that has a value of 150, this function will return 150. |
Return smaller value out of two | Selects the lesser value from two options. For example, if you specify a value of 100 and select a field to compare that value that has a value of 150, this function will return 150. |
Round | Rounds numbers up or down to the next closest integer. For example, using it on a value of 5.9 would result in 6, while a value of 5.1 would result in 5. |
Round down | Rounds numbers down to the next lowest integer. For example, using it on a value of 5.9 would result in 5. |
Round up | Rounds numbers up to the next largest integer. For example, using it on a value of 5.01 would result in 6, while using it on 5.0 would result in 5. |
Subtract | Subtracts a given number from a field, or use another field's values to subtract from it. For example, use it to subtract 100 from all "Clicks", or to subtract "Costs" from "Revenue". |
Sum | Sums up the values from a field with a given number or values from another field. For example, use it to add "Taxes" to "Net Revenue" to form a "Gross Revenue" metric. |
Trim | Strips whitespaces, tabs, and return carriage from the beginning and end of a field's values. |
Upper case | Converts every letter in a text string to a capital letter. For example, using it on "Black Friday" would convert the text to "BLACK FRIDAY". |
Upper case first letter | Converts the first letter of a text string into a capital letter. For example, using it on "black friday" would convert the text to "Black friday". In addition, with the "All Words" setting selected, "black friday" would be converted to "Black Friday", i.e. the first letter of all words in your string would be converted to upper case. |
