Follow this guide to connect your Everflow data to Supermetrics.
To connect Supermetrics to your Everflow account, you need to create an API key.
- Log in to the Everflow platform
- From the left menu, expand the menu by clicking on the arrow icon at the bottom.
- From the menu navigate to Control Center → Security.
- Click + API key.
- Give a name for your API key, select the employee, and select at least the permission Reporting.
- Click Create API Key.
Your key will be displayed in the Generated Keys table.
- Performance
- Under Data source, select Everflow.
- Enter your API Key.
- Enter a name for your account so that you can identify it later.
- Navigate to Everflow and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Everflow requires authorization to connect to data").
- Enter a name for the account so that you can identify it later.
- Click Start to connect.
