Use this guide to connect Simeplsat to Supermetrics, and start pulling your review data into your reporting.
To connect Supermetrics to Simplesat, you need:
- Your account/API key, which you can find on the Account settings page in your Simplesat account. Read Simplesat's documentation to learn how to find your account/API key.
- Under Data source, select Simplesat.
- Enter your credentials and click Log in.
- Click Allow.
- Navigate to Simplesat and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Simplesat requires authorization to connect to data").
- Click Allow.
- Click Allow.
