Yandex.Direct and Yandex.Metrica: Query setup guide
Once you’ve authenticated your connection to Yandex.Direct and Yandex.Metrica, you’re ready to create your first query.
This guide will walk you through Yandex.Direct and Yandex.Metrica query setup for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and API.
To connect Supermetrics to Yandex.Direct, you need:
To connect Supermetrics to Yandex.Metrica, you need:
Available fields
Visit our documentation site for a full list of the metrics and dimensions Supermetrics can pull from Yandex.Direct and Yandex.Metrica
Google Sheets Data Studio Excel Data Integrations
  1. Authenticate the data source in Google Sheets
  2. Select Dates. Choose one date range (today, yesterday, last week, etc.). To select a custom date, you can insert the date manually in the Start and End fields in the calendar bar.
  3. Select Metrics
  4. Select Split by Dimensions.
    You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted.
  5. Click Get Data to Table to create your query and pull your data.
