Centra connection guide
This guide contains all permissions and requirements for connecting your Centra data to Supermetrics.
You need an API Token and an Endpoint URL in order to connect to Centra.
How to create an API token
  1. Log in to your Centra Dashboard.
  2. In the navigation on the left, go to System → API tokens.
  3. In the top right corner, click Create integration API token.
  4. Enter the required details such as an expiration date and description so that you can easily identify the API token later, for example "Supermetrics".
  5. In the Stores list, select at least one store that you want to fetch data for.
  6. Under permissions, select the follow Read permissions:
    1. Order details
    2. Order.shippingAddress
    3. Return details
    4. Shipment details
    5. Product details
    6. Market details
    7. PaymentHistory
  7. Click Save.
How to find your Endpoint URL
  3. The Endpoint URL is visible at the top of the page. It should follow the format "https://shop-name.centra.com/graphql".
  • Order items
  • Return items
When connecting to Centra, you need to log in to Centra and enter your Endpoint URL and API token.
  1. Select the Centra data source on the Supermetrics Hub or in the data destination.
  2. Insert the Endpoint URL, API token and give a name for your log in.
  4. Click Start.
  5. In your data destination, select the store(s) to fetch data for and query type to use.
You can also connect to Centra from these destinations:
