Follow these steps to connect your Hotjar data to Supermetrics and use your data in Google Sheets, Looker Studio, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the Hotjar connector, make sure that your Hotjar plan includes access to their API. See this Hotjar support article for information on how to subscribe to API access.
To connect Supermetrics to your Hotjar account, you need to generate API credentials (client ID and client secret) as well as the site ID for the site you want to fetch data for.
- Log in to the Hotjar platform.
- Open the Organization Settings page
- Click API from the left menu bar.
- Select your organization.
- Enter a name for the credential, for example “Supermetrics”.
- For scopes, select “Survey responses”.
- Click Generate credentials.
- Copy the Client ID and Client secret to a safe place for later reference.
- Open the Sites & Organizations page.
- The site ID is in the left-most column in the table, next to the site name.
- Surveys: Behavior analytics and feedback data to help users empathize and understand their customers through surveys tool.
- Under Data source, select Hotjar.
- Enter your Client ID, Client Secret, and Site ID.
- Enter a name for your site so you can identify it later.
- Navigate to Hotjar and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Hotjar requires authorization to connect to data").
- Click Select data source.
- Select the Hotjar data source.
- Fill in the query details.
- In the sidebar, click API.
- Hover over the Hotjar data source, and click Connect.
