Follow these steps to connect your Snapchat Marketing data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Your Snapchat user account needs at least Account Admin or Campaign Manager access to an ad account before you can connect it to Supermetrics.
- Under Data source, select Snapchat Marketing.
- Enter your account details, and click Continue.
- Click Continue a second time.
- Navigate to Snapchat Marketing and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Snapchat Marketing requires authorization to connect to data").
- Click + Create transfer.
- Select the Snapchat Marketing data source.
- Accept the agreement.
- Click Authorize with Snapchat Marketing.
- Click Submit.
- Click Save.
- Click Create new.
- Select the Snapchat Marketing data source, and click OK.
- Click Create transfer.
- Click Select data source.
- Fill in the query details.
- Hover over the Snapchat Marketing data source, and click Connect.
- Snapchat Marketing report building guide
- How to reauthenticate a data source in Looker Studio, Google Sheets, or Excel
- How to reauthenticate a data source in data warehouse, API, or cloud storage platform
- How to manage data source connections on the Supermetrics Hub
