TikTok Organic connection guide
Follow these steps to connect your TikTok Organic data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To fetch data using the TikTok Organic data source connector, you need to connect to the data source using your TikTok Business or Personal account. Note that the personal account needs to have at least 100 followers, analytics enabled, and at least one public post to get data through the connector.
You log in to Supermetrics TikTok Organic connector with the same credentials that are used for logging in to the TikTok profile on the TikTok mobile app.
  • Profile overview: Get profile-level data on how many people started to follow you, viewed your profile, or viewed or engaged with your profile. Profile data is available for the last 60 days and can be broken down on a daily level.
  • Content performance: Get video-level data on how many people viewed your video, engaged with your video, or how long your videos were watched on average. Video data is available as lifetime value per video. This means the video performance data can't be broken down for a specific date range or by date.
  • Followers by country: Get a percentage distribution of your follower base by country.
  • Followers by gender: Get a percentage distribution of your follower base by gender.
  3. Click Create new query.
  4. Under Data source, select TikTok Organic.
  6. Click Start.
  7. Log in to the TikTok account you want to fetch data from.
  8. Click Authorize to allow the Supermetrics app to access your profile data.
  9. Click Start.
  10. Select a query type.
  2. Navigate to TikTok Organic and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "TikTok Organic requires authorization to connect to data").
  7. Click Start.
  8. Log in to the TikTok account you want to fetch data from.
  9. Click Authorize to allow the Supermetrics app to access your profile data.
  10. Click Start.
  11. Select a query type to use in your report, and click Next.
  12. In the pane's top right, click Connect.
  13. Click Create report.
  14. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select TikTok Organic.
  5. Click Start.
  6. Log in to the TikTok account you want to fetch data from.
  7. Click Authorize to allow the Supermetrics app to access your profile data.
  8. Click Start.
  9. Select a query type.
Data warehouse
  3. Click + Create transfer.
  4. Select the TikTok Organic data source.
  7. Accept the agreement.
  8. Click Authorize with TikTok Organic.
  9. Click Start.
  10. Log in to the TikTok account you want to fetch data from.
  11. Click Authorize to allow the Supermetrics app to access your profile data.
  12. Click Start.
  13. Select the accounts you'd like to include in your reporting and define the transfer settings.
  14. Click Submit.
  15. Click Save.
  3. Click Create new.
  4. Select the TikTok Organic data source, and click OK.
  7. Click Start.
  10. Click Start.
  11. In the transfer setup view, select the accounts you'd like to include in your reporting.
  12. Click Create transfer.
Power BI
  3. Click Select data source.
  5. Click Start.
  8. Click Start.
  9. Fill in the query details.
  10. Click Run query to test your query.
The Supermetrics API
  4. Click Select data source.
  5. Select the TikTok Organic data source.
  6. Click Start.
  9. Click Start.
  10. Fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  11. Click Run to test your query.
Supermetrics Hub
  4. Hover over the TikTok Organic data source, and click Connect.
  5. Click Start.
  8. Click Start.
