X Ads (Twitter) connection guide
Follow these steps to connect your X Ads (Twitter) data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Your Twitter Ads account needs Campaign analyst access to pull data with Supermetrics. Some dimensions might also need Ad manager access to an ad account. Learn how to grant ad account access.
  2. Navigate to Extensions  Supermetrics  Launch to open the Supermetrics sidebar.
  3. Click Create query.
  4. Under Data source, select X Ads (Twitter).
  6. Click Start.
  7. Enter your credentials, and click Sign in.
  8. Select the accounts you'd like to include in your reporting.
  2. Navigate to X Ads (Twitter) and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "X Ads (Twitter) requires authorization to connect to data").
  7. Click Start.
  8. Enter your credentials, and click Sign in.
  9. Select the accounts you'd like to include in your reporting.
  10. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select X Ads (Twitter).
  5. Click Start.
  6. Enter your credentials, and click Sign in.
  7. Select the accounts you'd like to include in your reporting.
Data warehouse
  3. Click + Create transfer.
  4. Select the X Ads (Twitter) data source.
  7. Accept the agreement.
  8. Click Authorize with X Ads (Twitter).
  9. Click Start.
  10. Enter your credentials, and click Sign in.
  11. Select the accounts you'd like to include in your reporting and define the transfer settings.
  12. Click Submit.
  13. Click Save.
  3. Click Create new.
  4. Select the X Ads (Twitter) data source, and click OK.
  7. Click Start.
  9. In the transfer setup view, select the accounts you'd like to include in your reporting.
  10. Click Create transfer.
Power BI
  3. Click Select data source.
  5. Click Start.
  7. Fill in the query details.
  8. Click Run query to test your query.
The Supermetrics API
  4. Click Select data source.
  5. Select the X Ads (Twitter) data source.
  6. Click Start.
  8. Fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  9. Click Run to test your query.
Supermetrics Hub
  4. Hover over the X Ads (Twitter) data source, and click Connect.
  5. Click Start.
