How to query for specific conversions in Google Ads
Use a simple query in Supermetrics to pull data for specific conversions in Google Ads.
  1. Create a new query in your destination.
  2. Set your metric to Conversions.
  3. Set your dimensions to Conversion type or Conversion category.
  4. Run your query.
This also works with the Conversion tracker ID and External conversion source dimensions.
Warning
Several metrics in Google Ads aren’t compatible with conversion-based dimensions. This means you won’t be able to query these metrics if your dimension is set to Conversion type or Conversion category.
Find details on which metrics are incompatible with these dimensions in Google Ads’ API documentation.
