Yandex.Direct & Yandex.Metrica connection guide
Follow these steps to connect your Yandex.Direct and Yandex.Metrica data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub. Yandex.Direct is also available for data warehouse destinations.
To connect Yandex data sources, you need Chief Representative or Representative user access. Learn more about Yandex user roles.
  3. Click Create new query.
  4. Under Data source, select Yandex.Direct or Yandex.Metrica.
  6. Click Start.
  7. Enter your credentials, and click Log in.
  8. Click Allow.
  2. Navigate to Yandex.Direct or Yandex.Metrica and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Yandex requires authorization to connect to data").
  7. Click Start.
  8. Enter your credentials, and click Log in.
  9. Click Allow.
  10. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Yandex.Direct or Yandex.Metrica.
  5. Click Start.
  6. Enter your credentials, and click Log in.
  7. Click Allow.
Data warehouse
  3. Click + Create transfer.
  4. Select the Yandex.Direct data source.
  7. Accept the agreement.
  8. Click Authorize with Yandex.Direct.
  9. Click Start.
  10. Enter your credentials, and click Log in.
  11. Click Allow.
  13. Click Submit.
  14. Click Save.
  3. Click Create new.
  4. Select the Yandex.Direct data source, and click OK.
  7. Click Start.
  9. Click Allow.
  11. Click Create transfer.
Power BI
  3. Click Select data source.
  4. Select the Yandex.Direct or Yandex.Metrica data source.
  5. Click Start.
  7. Click Allow.
  8. Fill in the query details.
The Supermetrics API
  4. Click Select data source.
  5. Select the Yandex.Direct or Yandex.Metrica data source.
  6. Click Start.
  8. Click Allow.
Supermetrics Hub
  4. Hover over the Yandex.Direct or Yandex.Metrica data source, and click Connect.
  5. Click Start.
  7. Click Allow.
