This guide contains all permissions and requirements for connecting your Shopee Ads data to Supermetrics.
To pull commerce data from Shopee using Supermetrics, you need a Shopee account.
In addition, you need:
- You must authenticate using a normal Shop account. Sub-accounts are not compatible with the connector.
- You need the email/phone number/user name and password of the Shop account.
Learn more about different types of Shopee accounts.
- CPC Ads: Retrieve performance data for CPC ads.
When connecting to Shopee Ads, you need to log in to Shopee Ads and select the shop region when prompted.
- Select the Shopee Ads data source on the Supermetrics Hub or in the data destination.
- Select your store region from the dropdown.
- Select your store region from the dropdown and insert your email/phone number/user name and password.
- Confirm the authorization for Supermetrics to access your Shopee data.
- In your data destination, select the stores to include in your reporting and a query type, if prompted.
You can also connect to Shopee Ads from these destinations:
