Use the Ahrefs data source connector to pull data such as URL and domain rankings, traffic metrics, and backlink details. Create a report to identify which websites the traffic is coming from and build a detailed technical SEO report to fix and improve your website pages and links.
For a full list of metrics and dimensions available in our Ahrefs data source connector, take a look at our Ahrefs documentation.
Once you’ve connected to Ahrefs, you're ready to create your first queries!
When connecting to the Ahrefs data source, you need to select a query type. The query type defines what sort of metrics and dimensions are available.
- Overview: Pull overview metrics from Backlink profile, Organic search and Paid search.
- Backlinks: Understand specific referring pages yielding high and/or low traffic and their overall domain rating
- Referring domains: Shows website domains for which target URL is referring
- Organic keywords: Shows the organic keywords for which the target URL ranks for
- Top pages: Shows which pages of the target URL get the most organic search traffic
- Paid pages: Shows which pages of the target URL get the most paid search traffic
- Keyword explorer: Overview: Get relevant keyword ideas with search volume, keyword difficulty, and other advanced metrics
Try these queries
See paid and organic traffic
Use the "Overview" query type.
The "Paid traffic" metric shows an estimation of the number of monthly visits that your target gets from paid search for a keyword. The "Organic traffic" metric shows an estimation of the number of monthly visitors that your target gets from organic search for a keyword.
- Select the Overview query type and insert the target URL.
- Select the Paid traffic and Organic traffic metrics.
- Select the Target URL dimension to split the query results by the target URL.
See backlinks and domain rating
The "Backlink count" metric shows the total number of links from other websites pointing to your target. The "Referring domains" metric shows the total number of unique domains linking to your target. The "Domain rating (DR)" metric shows the strength of a domain's backlink profile compared to the others in our database on a 100-point scale.
- Select the Backlink count, Referring domains, and Domain rating (DR) metrics.
- Select the Target URL metric to split the query results by the target URL.
See Ahrefs rank
The "Ahrefs rank" metric shows the strength of your target's backlink profile compared to the other websites in our database, with rank #1 being the strongest.
- Select the Ahrefs rank metric.
