How to load data from Supermetrics Storage to Power BI
Follow this guide to load your data from your Supermetrics Storage to your Power BI instance.
Step 1: Create a transfer to your Supermetrics Storage
  1. Create a transfer to your Supermetrics Storage. See the instructions on how to create a transfer.
  2. Confirm that the transfer was successful and that your Storage has data.
Step 2: Load the data to your Power BI instance
  1. In Power BI, click Get data in the ribbon.
  2. Search for GoogleBigQuery.
  3. Click OK.
  4. Sign in to your Google Account.
  5. Click Allow to allow Power BI to access your Google Account. Close the window and return to the Power BI instance.
  6. Click Connect.
  7. In Navigator, select the table groups to load to Power BI, and click Load.
  8. In the Connection settings window, make sure that Import is selected, and click OK.
  9. Once the data has been loaded to Power BI, you can see the table groups in the Data sidebar.
