Use this guide to connect any Google data source to Supermetrics.
Note that while these data sources share the same connection steps, each has unique permissions that you need to implement before you'll be able to connect. Make sure you've assigned these permissions before going ahead.
Select a Google data source from the list below to learn about its permissions and other connection requirements.
- You'll need a Google Ads or manager account with Read Only access. Learn how to grant access to a Google Ads account or manage your accounts.
- You'll need a Google AdSense account with at least the Admin user role. Learn how to manage user access to your account.
- You'll need a Google Ad Manager account with at least the Trafficker role. API access must be explicitly enabled by the Administrator.
- Learn about role permissions and how to manage user roles, and how to enable API access.
- You'll need a Google Analytics account with at least Read & Analyze access to a Property and Views underneath. Learn more about user permissions and how to add users.
- You'll need BigQuery Data Viewer and BigQuery User role levels for the Dataset, and the BigQuery User role for the Project.
Google BigQuery field list types
- Simplified field list: Shows each unique field name just once, if it's present in multiple tables.
- Full-field list: Shows all columns from your tables in BigQuery.
- Simplified list: With join fields only — shows only the fields that are available for multiple data sources.
- You'll need a Google Account with an appropriate user role for the reporting content they need to see (this varies based on what the admin set for the role). Read more about user access in Google’s documentation.
- You might need API access for the account enabled by a Google representative or the Campaign Manager 360 support team. Learn more about API prerequisites.
- You'll need a Google Display & Video 360 account with at least a Standard or Admin user role. Learn how to manage user access.
- You'll need a Google Account with at least an Owner or Manager user role. Learn how to add and remove owners and managers.
- Please note that you can fetch only limited locations. Learn about usage limits on Google My Business API.
- You'll need a Google Search Ads 360 account with at least an Agency Manager or Advertiser Manager role. Learn how to add or remove users.
- Following Supermetrics' migration to a new Google Ads API in early 2022, it's no longer possible to pull Google Ads data from Search Ads 360 accounts. Remove any Search Ads 360 accounts from your queries to keep them running.
- You'll need a Google Search Console account with Verified Owner or Delegated Owner access. Verify your site ownership first.
For Excel users
- Under Data source, select your Google data source.
- Sign in with the Google Account you use with this data source. This doesn't have to be the same as the Google Account you use with Supermetrics.
- Click Allow.
- Navigate to your Google data source and click Try.
- Click Authorize.
- If you're connecting your Google data source for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Click Allow.
- Click Allow.
