Follow these steps to connect your Campaign Monitor data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Campaign Monitor, you need a Campaign Monitor account with an Admin user role.
- Campaign summary (sent): Follow your email campaigns' performance.
- Under "Data source", select Campaign Monitor.
- Enter the email address and password you use with Campaign Monitor.
- Click Continue, and then Allow access.
- Navigate to Campaign Monitor and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Campaign Monitor requires authorization to connect to data").
- Select the accounts to use in your report and a query type.
- Click Next.
- Click + Create transfer.
- Select the Campaign Monitor data source.
- Accept the agreement.
- Click Authorize with Campaign Monitor.
- Click Submit.
- Click Save.
- Select the Campaign Monitor data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Campaign Monitor data source, and click Connect.
