Follow these steps to connect your Bambuser data to Supermetrics.
To connect Supermetrics to your Bambuser account, you need your Bambuser base URL and a copy of your API key.
Get your base URL
- Log in to Bambuser, and open your dashboard.
- Take a look at the URL in your address bar.
If it begins with lcx.bambuser.com/, then your base URL is:
https://liveshopping-api.bambuser.com/v1.
If it begins with lcx-eu.bambuser.com/, then your base URL is:
https://liveshopping-api-eu.bambuser.com/v1.
Get your API key
- On the left-hand side, click Settings.
- Under "Settings", click Integrations.
- Select "API keys".
- Find the API key you want to copy, and click Copy. Store this in a secure place. If you don't see an API key here, contact Bambuser support.
For Excel users
- Navigate to Extensions → Supermetrics → Launch sidebar to open the Supermetrics sidebar.
- Under Data source, select Bambuser.
- Give your account a memorable name.
- Enter the base URL and API key.
- Navigate to Bambuser and click Try.
- Click Authorize.
- If you're connecting Bambuser for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Deets
