Follow these steps to connect your Stripe data to Supermetrics, and start adding it your reports.
To connect Supermetrics to Stripe, you need the Administrator user role level. Learn about user roles and permissions for team members in Stripe's documentation.
Note that you can't run queries with 2 Stripe accounts simultaneously. Log out and back in with a different account to create queries for 2 separate accounts.
- Under Data source, select Stripe.
- Enter your email address and password, and click Log in.
- Select the account you want to use, and click Connect.
- Navigate to Stripe and click Start free trial.
- You'll see two buttons saying Authorize. If you're using Supermetrics for the first time, click the left-hand one and log in with the Google Account you use with Supermetrics.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Stripe requires authorization to connect to data").
