Stripe reconnection required - July 15, 2025
We have migrated our Stripe data source to a Stripe App to take full advantage of all the Stripe features. Due to this migration, all Stripe data source users need to switch to the Stripe App by July 15, 2025. To switch the Stripe data source to use the Stripe App, all users need to log in to Stripe again.
What you need to do
As soon as you can, please reconnect your Stripe account using the steps in our Stripe connection guide. If you have multiple Stripe accounts, you'll need to repeat these steps for each one.
In case reconnecting generates a separate new connection, you can go to Supermetrics Hub and replace the old connection with the new one to ensure your queries continue running uninterrupted.
We'll retire the old Stripe connections on July 15, 2025, so please reconnect the Stripe data source by that date to have a smooth transition.
We’re here for you
If you have any questions or concerns about this change, contact our support team.
