This guide contains all permissions and requirements for connecting your PrestaShop data to Supermetrics.
You need a Webservice key and your Webservice URL in order to connect to PrestaShop.
You first need to enable the Webservice API from your PrestaShop back office.
- Log in to the back office of your shop.
- Click Settings from the left-hand side navigation bar.
- Expand the Advanced Parameters menu and click Webservice.
- Scroll down to Configuration.
- Set Enable PrestaShop Webservice to Yes.
- In the PrestaShop backoffice, navigate to Settings → Advanced Parameters → Webservice.
- Click the Add new webservice key button.
- Click Generate to create a new random API key.
- Enter a Key description to help you remember the purpose, for example you can set the description to Supermetrics.
- Set Enable webservice key to Yes.
- For permissions, enable the View (GET)permission for the following resources:
- currencies
- customers
- orders
- order_states
- shops
- Multistore mode only: For Shop association, please select which of your stores your Supermetrics connection should have access to.
- Click Save.
- Record the generated key in a safe and secure place.
- For additional information, see Prestashop's documentation here.
To obtain your webservice URL, navigate to the front page of your Prestashop by clicking View my store in the upper right corner of the Prestashop back office.
If Prestashop is installed at the root of your server (the most common case), the webservice URL is the part of the URL before the first trailing slash /, typically it looks like this:
https://example.com
In case your Prestashop is installed in a subfolder of your server, the URL looks like this: https://example.com/prestashop
In both cases, make sure your webservice URL does not have a trailing slash / at the end.
- Orders: Fetch detailed insights about your shop orders.
When connecting to PrestaShop, you need to enter your webservice URL and webservice key when prompted.
- Select the PrestaShop data source on the Supermetrics Hub or in the data destination.
- Insert the webservice URL, webservice key, and give a name for your connection.
You can also connect to PrestaShop from these destinations:
