Follow these steps to connect your data from The Trade Desk to the reports you create with Supermetrics.
To connect Supermetrics to The Trade Desk, you need the Partner-level reporting user role and access to partner cost metrics. There might be fees associated with API access that you'll pay to The Trade Desk.
Note that you'll need to sign a form with The Trade Desk to grant access to your data. Like any third-party supplier, Supermetrics isn't involved with the creation of this document.
- Under Data source, select The Trade Desk.
- Enter your email address and password, and click Start.
- Navigate to The Trade Desk and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "The Trade Desk requires authorization to connect to data").
