If you want to query for specific conversion types in Microsoft Advertising data, follow the example below.
Use this basic query setup to get the types of conversions that your Microsoft Advertising queries are using.
- Metrics: Conversions
- Dimension: Goal
Caution
Many other metrics are not compatible with the Goal dimension, so you won't be able to query them at the same time. However, you may be able to add another dimension to use as a key value, like campaign ID or Name, and pull a second query with the same key value that you can then join together with the key value.
