Use this guide to connect your Smarp data to the reports you create with Supermetrics.
To connect Supermetrics to Smarp, you need:
- An account name. This is the name you choose for your login. We recommend using your account's name.
- A Smarp subdomain. This is the subdomain from your URL.
- This is found after the https:// in your Smarp URL. For example, in the URL https: //examplestore.smarpshare.com, examplestore is the Smarp subdomain.
- An API key. You'll find this in the Smarp dashboard — remember to keep it safe once you have it. Read the Authentication section of Smarp's basic concepts documentation to learn more.
To access most query types, you'll need the Company Admin role level.
- Clicks: Returns all clicks based on the period in which clicks happened.
- Campaigns: Returns campaigns for a specific company.
- Groups: Returns all groups within the instance.
- Posts: Returns posts based on the period in which posts were published.
- Posts that have been deleted or were published in private channels won't be returned.
- Shares: Returns all shares based on the period in which the share was done.
- Teams: Returns all teams in the instance.
- Users: Returns users in the company.
- Under Data source, select Smarp.
- Enter your account name, Smarp subdomain, and API key.
- Select your query type.
- Navigate to Smarp and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Smarp requires authorization to connect to data").
