This guide contains all permissions and requirements for connecting your Google Play Console data to Supermetrics.
Before using the Google Play Console connector, you need access to Google Play Console developer account with access level User. Learn how to add developer account users and manage permissions.
You also need your Cloud Storage URI. To find your Cloud Storage URI:
- Log in to Google Play Console.
- Go to Download reports.
- Select any report.
- Select Copy Cloud Storage URI.
- Statistics: Fetch data for Installs, Crashes and Ratings metrics
- Reviews: Fetch reviews data for your app
When connecting to Google Play Console, you need to provide your Cloud Storage URI and select an account to use when prompted.
- Select the Google Play Console data source on the Supermetrics Hub or in the data destination.
- Enter your Cloud Storage URI.
- Select the Google account associated with the Google Play Console account from which you want to fetch data.
- Click Allow to allow the Supermetrics app to access your profile data.
- In your data destination, select the query type to use.
You can also connect to Google Play Console from these destinations:
