Quantcast connection guide
Follow this guide to connect your Quantcast data to Supermetrics.
To connect Supermetrics to Quantcast, you need:
  • A copy of your account ID
  • An API key
  • An API secret
Get your account ID
  1. Log in to Quantcast.
  2. Click Account list in the top right.
  3. Click View all.
  4. Copy the account ID for the account you want to connect.
Get your API key and API secret
  2. In the top right, click the Profile icon, and then My profile.
  3. Navigate to the "API key" section, and click Create API Key.
  4. Quantcast will show your API key and API secret once. Copy these — remember to keep them safe and secure.
Supermetrics supports the Campaigns query type, which measures the performance of your advertising campaigns.
Google Sheets Looker StudioExcel
  3. Click Create new query.
  4. Under Data source, select Quantcast.
  5. Give your account a memorable name.
  6. Enter the Account ID for the account you want to connect.
  7. Enter that account's API key and API secret.
  8. Click Start.
