Capterra PPC connection guide
This guide contains all permissions and requirements for connecting your Capterra PPC data to Supermetrics.
To connect Supermetrics to Capterra PPC, you need API access and an API key enabled by the Capterra account manager.
  • Clicks: Get the basic metrics for a premium placement
When connecting to Capterra PPC, you need to enter your account name and API key.
  1. Select the Capterra PPC data source on the Supermetrics Hub or in the data destination.
  2. Enter your account name and API key.
  4. Click Start.
  5. In your data destination, select the account to pull data from and a query type, if prompted.
You can also connect to Capterra PPC from these destinations:
